SOURCE: knob on oven is not working properly
The knob is probably cracked, if you can pull it off, then you can try to see if you can turn the oven off with a pair of grips or pliers, if you can, then you just need to replace the knob, if not then you will have have to replace the switch.
SOURCE: BOTTOM OVEN WIILL NOT HEAT
check the bottom heat element and see if you see any burn out spots on it,if so you will have to replace it(easy)let me now-mike
SOURCE: We've inherited a belling electric double oven.
seems the heating element burnt out, inspect it for small melted section, element needs replacing, about 25$ at hardware store
SOURCE: bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
SOURCE: Belling XOU 252 Oven suddenly stopped working
need new element that is element code "AB20" from link below you need to remove 2 screw or nuts that holds back plate element is behind it then pull oven out remove back cover remove element wires and put every thing reverse order
element code is AB20 link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
