Ovens Logo
Question about Belling Ovens
Belling Classic 110DFT. How do you replace grill element please?
The reason I ask is do you have to remove the whole oven to reach the back of the connection. I can't pull it out, can I unscrew the element from the front and reconnect the new part that way?
Posted by Davinder Puri on
ADMIN Andrew
    Top Expert:
  • Belling Master
  • 53,121 Answers
Question edited for clarity.
Yes, normally you remove the door for ease of access, then remove the shelves and access the element from the front. Then undo the fixing screws and pull the element forward. The contacts have enough wire you can pull the element forward to undo the electrical contacts. Make sure the power is OFF! See the videos.
https://www.google.com/search?q=belling+classic+110dft+replace+element
Posted on Feb 03, 2022
Testimonial: "Lovely, a great help!"
  • ADMIN Andrew
    ADMIN Andrew Feb 04, 2022
    you are very welcome :>D
Belling classic 900e grill & hotplates not working
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
2helpful
HOW DO YOU INSTALL A REPLACEMENT TOP OVEN GRILL ELEMENT IN A XOU500SS BELLING DOUBLE OVEN
remove the appliance so you can access the back panel. Make sure it is switched off at the wall and unscrew the nuts holding the element in place. disconnect the wires making sure to remember which wire went where. unscrew the screws holding the element inside the oven and remove. Reverse process to install new element
7helpful
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
1helpful
Grill is working but oven wont heat up
You need to replace the oven element, it is located at the rear of the oven behind a removeable panel.
Please rate my sol;ution.
Thanks.
My grill element belling xou177 duel grill does not work, i carnt afford a new one was told be an oven specailist he would disconect wires for £30, i carnt afford this either, i need to know whic...
If you can locate the wires to the element, simply pull them off, and tape the ends of the wires to make them safe, make sure you mark them so you know where they go back.It will probably invlve you having to remove the rear panel to gain access.
Thanks.
Nov 10, 2009 • Ovens
2helpful
3answers
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Belling oven
you will have to replace the main oven element...
15helpful
3answers
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
1helpful
2answers
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
