20 Most Recent Belling XOU492 Electric Double Oven Questions & Answers
3answers
Beko oven fan catching element everything secure making dreadful row
Your oven must be fairly level for the fan not to make a noise.
6/5/2019 5:30:27 PM • Belling XOU492... • Answered on Jun 05, 2019
Belling gas oven won't work Model XOU70G Mk 11
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse. THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
5/3/2015 5:58:52 AM • Belling XOU492... • Answered on May 03, 2015
2answers
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker cooker parts Need help fixing your appliances these repair guides will also help you find and understand the exact problem with your cooker How to Repair and if we really helped you you could always buy us a beer Buy Paul Beer
4/2/2015 2:55:34 PM • Belling XOU492... • Answered on Apr 02, 2015
Belling 492 bl short out when oven turned on
Sounds like the oven element is broken, replacement at http://www.elementreplacement.co.uk/belling-elecr11budget-332-p.asp Check dimensions with the one shown
4/15/2014 11:19:06 AM • Belling XOU492... • Answered on Apr 15, 2014
2answers
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
4/6/2014 3:25:56 PM • Belling XOU492... • Answered on Apr 06, 2014
I have an Indesit oven FI 31 KB. It is 3 years old
sometimes there is a switch that operates when the door is opened or closed causes the fan to stop when the door opens. The switch is normally mounted at a door hinge, or hinge bracket.might have to remove a panal to get to it
10/20/2013 6:31:29 AM • Belling XOU492... • Answered on Oct 20, 2013
manual
I have a Belling 492 SS built in double oven and
I'm afraid it means replacing the whole clock/timer unit, there is no otther way around the problem.
1/4/2011 10:33:43 PM • Belling XOU492... • Answered on Jan 04, 2011
Switch on main oven starts to heat then trips out
Yes this is a frequent problem with thermostats. The thermostat is an electric switch which from overheat and long time use they malfunction and you need to replace it.
11/25/2010 6:46:49 PM • Belling XOU492... • Answered on Nov 25, 2010
2answers
How do I change the oven element on a belling
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
8/25/2010 10:52:32 AM • Belling XOU492... • Answered on Aug 25, 2010
tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
Belling double electric fan oven
Get similar instructions here
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
3/29/2010 2:00:19 PM • Belling XOU492... • Answered on Mar 29, 2010
We have a belling format oven - when we turn the
The noise is probably cominbg from the externally mounted cooling fan. to access it, you will have to remove the side panel and rear cover, and top cover if it is bullt in.
If it is free standing, you should be able to get to it by removing the top cover/hob.
Hope this helps.
12/7/2009 8:01:08 PM • Belling XOU492... • Answered on Dec 07, 2009
The main oven door will not shut tightly, how do
if its a pull down door the hinges are prob worn and need replacing.
9/28/2009 8:22:50 AM • Belling XOU492... • Answered on Sep 28, 2009
NEED INSTRUCTIONS FOR USE OF BELLING E298
Try clicking on this link:
http://www.belling.co.uk/brochure.aspx
Please rate my fixya solution.
Thanks.
2/13/2009 10:35:53 AM • Belling XOU492... • Answered on Feb 13, 2009
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
4/12/2008 7:31:01 PM • Belling XOU492... • Answered on Apr 12, 2008
Replacing timer unit
if like other belling, take side panels off. take off screws holding hobtop and move it backwards. clock should be then accessible
4/2/2007 8:32:53 PM • Belling XOU492... • Answered on Apr 02, 2007
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
3/20/2007 4:43:22 PM • Belling XOU492... • Answered on Mar 20, 2007
Belling XOU492 Electric Double Oven Logo
Popular Tags
49 questions posted
Top Belling Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Belling Oven Expert? Answer questions, earn points and help others
View Most Popular
Belling Ovens
  • Belling Ovens
Most Popular Question
change oven element belling
  • Ovens
