Samsung Microwave SMH7159 won't work after a power outage. Tested plugin, it's good. Replaced fuse, that didn't fix it. When I plug in the microwave to the outlet the power fan plate comes out, but no lights on the touch panel.
SOURCE: GE Spacemaker XL1800 (JVM1860WD 002) Stoped Working.
The control panel has built-in surge protection, and the high voltage probably tripped that. It will have to be repaired, which we do nationwide for only $39.95 postpaid. By rights, I would say the electrician should be the one to see to the repairs, including removing the control panel assembly to send in for repair. We have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 Please let us know if you have any other questions.
SOURCE: Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
SOURCE: No power but outlet is functioning properly
There is a ceramic fuse inside the oven. Remove the case and follow the cord from the back of the oven to the fuse. Replace with on of the same amp size.
SOURCE: GE JVM1190SY/WY My microwave shows no signs of
Dead appliance, power on wall outlet. YOUR
SAFETY IS PARAMOUNT! Attempt
this only if you are competent. If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
SOURCE: GE Microwave JVM1540 will not turn on. I have
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
