Samsung Microwave SMH7159 won't work after a power outage. Tested plugin, it's good. Replaced fuse, that didn't fix it. When I plug in the microwave to the outlet the power fan plate comes out, but no lights on the touch panel.
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
SOURCE: Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
SOURCE: No power but outlet is functioning properly
There is a ceramic fuse inside the oven. Remove the case and follow the cord from the back of the oven to the fuse. Replace with on of the same amp size.
SOURCE: GE JVM1190SY/WY My microwave shows no signs of
Dead appliance, power on wall outlet. YOUR
SAFETY IS PARAMOUNT! Attempt
this only if you are competent. If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
