20 Most Recent
Emerson MW8108P Microwave Oven Questions & Answers
kitchen.manualsonline.com > ... > Emerson > Kitchen Appliance Emerson
Products 1 - 48 of 48 - Emerson Microwave Oven and Grill Owner's Manual. Pages: 0 ... Emerson OWNER'S MANUAL Microwave Oven MW8103SS. Pages: 0 ...
Emerson MW8108P...
Answered
on Aug 06, 2015
Depending on the age of it, you're better off properly disposing it and buying a new one.
Emerson MW8108P...
Answered
on May 04, 2012
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Emerson MW8108P...
Answered
on May 21, 2011
Quite
often this is due to grease or food particles stuck somewhere in the
cavity of the oven or stuck on or behind the waveguide cover.
The
waveguide cover (also called a spatter shield) is usually about the
size of a playing card and often held in place by a plastic rivet.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
If there is charring which cannot be cleaned off, the area will
have to be sanded smooth and
cleaned and dried thoroughly.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Home Depot, etc.If your
waveguide cover
is burned, it will need to be replaced.
It provides critical
protection for the magnetron.
For more help from
Emerson visit
here or get
help using your appliance at 1-800-898-9020. Get help locating an
authorized servicer or parts at 1-800-695-0098.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Emerson MW8108P...
Answered
on Dec 03, 2010
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers and Driver
downloads
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
Emerson MW8108P...
Answered
on Nov 04, 2010
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Emerson MW8108P...
Answered
on Mar 29, 2010
replac the drive motor . if its not the supports ( or wheels that it turns on ) ****
Emerson MW8108P...
Answered
on Jan 10, 2010
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Emerson MW8108P...
Answered
on Nov 23, 2009
