20 Most Recent Samsung SMH7159 Microwave Oven Questions & Answers
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Samsung SMH7159... | Answered on May 08, 2014
If the door doesn't work right it is time to buy another microwave. Microwave leaks can be dangerous.
Samsung SMH7159... | Answered on Oct 21, 2013
It sounds like the mount which holds tension on your door latch heads (door hooks) is broken. You can confirm that by pushing up on the door hook. If it goes up with no real resistance, the spring is unhooked. Fixing that would require disassembly of the door (by separating the panels) and repairing or replacing either the door hook assembly or the door panel inside.
Samsung SMH7159... | Answered on Jan 21, 2009
Probably magnetron failure- needs to go back to the dealers, this is a major job, may be cheaper to replace the oven
Samsung SMH7159... | Answered on Jan 09, 2009
unplug for five min then try it again!
Samsung SMH7159... | Answered on Dec 11, 2008
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
Samsung SMH7159... | Answered on Sep 23, 2006
I would purchase a new one as it will be impossible to clean and also the repairs required will be excessive
Samsung... | Answered on Sep 09, 2020
  • Open internal fuse
  • Magnetron failure
  • Control board failure
  • Door interlock failure
Samsung... | Answered on Mar 25, 2020
Sounds like you have burnt out the heat sensor.
Samsung... | Answered on Dec 17, 2019
Take it to a Samsung dealer for service, or get a new one. You can't service them yourself as they have security screws to stop you getting inside There is enough stored electricity inside to kill you, plus radiation to blind you and heavy metal elements to poison you.
The only thing you can do is verify it has power and the door is properly shut. Also, does it have a child lock
The control panel will cost more than a new microwave
Samsung... | Answered on Nov 26, 2019
Sounds like the switch(es) below the keypad pad(s) are sticking or failing. Unfortunately, replacement keypads tend to be expensive, perhaps too expensive for the value of the oven. Search for replacement parts by your Make and model.
Samsung... | Answered on Nov 03, 2019
YOu need to lock the time you set and leave the oven connected to power at all times.
Samsung... | Answered on Oct 18, 2019
Samsung SMH7159 Microwave Oven Logo
17 questions posted
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
panasonic microwave turn table rotates
  • Microwave Ovens
