A05
code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
The error message is that the oil is not reaching the set temperature in 16 minutes. Please contact AUTOFRY for more technical support. 1-800-348-2976 ext. 112
"Error A05 - Pressure switch has not been reset "
This is centered around the filter and drain area not working properly.
It is possible it just needs the filter cleaning and the hose flushing out, but also possible the pump needs to come out to clean it properly.
Drain it by putting the hose low down, and clean the filters of debris.
If this does not fix it, then remove the unit outside, lie on it's back and remove the pump to clean it.
the thing might be down to an old master stuck to the drum this could cause the faint copies and the missing print.. pull the drum out check under the master.this would also cause the paper to jam on exit. the error is for no master eject check the calmp is free where it grips the master and also the path for the master eject to the waste bin
