20 Most Recent Riso RZ220 Duplicator Questions & Answers
D?finir la langue du riso rp3700 du japonais vers fran?aise?
Riso RZ220... | Answered on Nov 03, 2020
A-17-209 is a cutter error meaning the cutter is not at home position when master material is in place. The cutter can be manually slide towards front of machine or another way is to rerolled master paper back on to its roll and close the clamp. This will cause the cutter, if operational, to re-home itself correctly. There are test codes to operate cutter to check it (480).
Riso RZ220... | Answered on Sep 16, 2020
Riso error code p98
Riso RZ220... | Answered on Feb 26, 2020
have to go in a change because its not riso ink...
Riso RZ220... | Answered on Nov 13, 2019
this is a very tricky problem on the main motor ther is a steel cap covering a strobe disk and a sensor the sensor is dirty or faulty to get to it you have to take out the main motor
Riso RZ220... | Answered on Oct 31, 2019
Sometimes when people lift the machine, they don't use the handles, there is a plate underneath the paper tray that bend, bend it straight and all will be fine
Riso RZ220... | Answered on Aug 26, 2019
Error code a06-403
Riso RZ220... | Answered on Jun 07, 2019
Clean the cartridge with alcohol, dry, put it back in .
Riso RZ220... | Answered on May 23, 2019
P01-538 is Print drum is not locked during operation. ( Drum lock sensor: OFF ) Check the drum release handle has not been forced to the "squeezed" open position.
Riso RZ220... | Answered on Apr 15, 2019
Depending on the error code, below is the list of error codes with explanations
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=RZ220
Riso RZ220... | Answered on Mar 15, 2019
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Riso RZ220... | Answered on Feb 28, 2019
where can i find the Riso RZ Paper-feed-tray upper or lower safety switch
111998
Riso RZ220... | Answered on Jan 11, 2019
Riso has the answer on the back page of the manual
Riso RZ220... | Answered on Aug 18, 2018
How could your ink work in a Riso RZ220?
Riso RZ220... | Answered on Jan 23, 2018
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Riso RZ220... | Answered on Jan 13, 2018
487 questions posted
Top Riso Office Equipment & Supplies Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Riso Office Equipment & Supplies
Most Popular Question
p 98 5 riso rz 370ep please help me
  • Office Equipment & Supplies
