Question about RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater
Comfort zone infrared heater keeps flashing A05 what does this mean?
Posted by Tammy Hartsoe on
L Pfaff
    Top Expert:
  • 11,573 Answers
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Posted on Jan 31, 2016
What is the A05 message mean?
A05 overheat condition, you must clean thoroughly,
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
I have a code A05. What does that mean?
Hold the two buttons on right with power on to reset.
Dec 19, 2012 | Comfort Zone CZ1500WC Infra-Red...
Why does my comfort zone infrared heater shut off after I turn it on? What modes does it have?
What is wrong with my Comfort Furnace heater if i have it turned off and it still keeps blowing ,Yet if i plug it back in it still comes on and i can turn it way down with it down on 55 and it will not shut of like it use to?
Oct 08, 2012 | Comfort Zone CZ1500WC Infra-Red...
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
Flashing A05 message
Hi. Did you see it http://www.fixya.com/support/t6866069-comfort_zone_infrared_hearter ? It's you possible decision...
Ted Infrared Heaters Guide
Dec 04, 2010 | Comfort Zone NEW 09 Electric Portable...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater Logo
1,770 people viewed this question
Top RTO Pool & Spa Experts
john h
Kardoc
Bill Boyd
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
