20 Most Recent RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater Questions & Answers
A05 overheat condition, you must clean thoroughly,
press the helpful button
RTO Comfort Zone... | Answered on Dec 02, 2017
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
RTO Comfort Zone... | Answered on Jan 31, 2016
It could be a variety of things, call the manufacturer, I would hope that the unit is still under warrantee.
RTO Comfort Zone... | Answered on Feb 28, 2013
I had the same problem, with a brand new unit. I wrote to the distributor, who said that I needed a new control board. They asked me a couple of questions about the unit (to figure out which control board I needed), and sent me a control board at no charge. (Your mileage may vary.) Installation took about 40 minutes with my 6yo helping me (20 minutes without the assistance), and fixed the problem.
FYI, the control board comes with the thermostat permanently attached -- I suspect that it was just the thermostat that needed replacing, but the entire control board goes with it as a single unit.
Final note: The instructions that we were provided for replacing the control board were incomplete in a couple of areas. Again, YMMV. You need to 'figure out' the information that isn't in the instructions in a couple of spots. Not rocket science, but not obvious if you're expecting the instructions to be well written and serve as an effective guide in completing the replacement.
- VS
RTO Comfort Zone... | Answered on Dec 23, 2010
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
RTO Comfort Zone... | Answered on Oct 03, 2010
Please give more detail.
RTO Pool & Spa | Answered on Jan 18, 2014
If you can see air swirling around, then there's bound to be water moving around. Otherwise you wouldn't see anything moving. You have a small suction leak somewhere. When you don't have the heater turned on, there's less strain on the pump and therefore less of a suction leak. Assuming your heater has an auto-bypass. Use your garden hose to find the suction leak and patch with silicone or pool putty. Or replace o-rings and gaskets. Check plugs and grease ports, etc.
Pool & Spa | Answered on Nov 25, 2020
check and test air pump --look up on internet for multi-sites that show how to test
Pool & Spa | Answered on Nov 21, 2020
Hi Don.
See if this link helps you out. https://nymag.com/strategist/article/best-alkaline-water-machines-filters.htmlps you out.
Pool & Spa | Answered on Nov 19, 2020
Failure of the older heating system
Pool & Spa | Answered on Nov 17, 2020
RTO Comfort Zone Electric Portable Space Infrared 1500-watt Heater Logo
20 questions posted
Top RTO Pool & Spa Experts
john h
Kardoc
Bill Boyd
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
RTO Pool & Spa
  • RTO Pool & Spa
Most Popular Question
model turns automatically off showing
  • Pool & Spa
