The display went out 2 days ago without warning..i can hear sounds and see a faint image with the flashlight..tried leaving power supply off for 24 hours with no luck
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Testimonial: "I have replaced the T-con board, the led ribbons and the main power board, but still no display. I can see faint images on the display and the sound is perfectly fine. What else could be the issue and would I need to replace the entire display?"
