Have tried removing batteries and then resetting the remote, no luck on reset. Also have tried, holding down the 'Mode' button for 5 secs you can choose from A,b,c or d. have tried all of these modes but display stays as fahrenheit The LCD display does have the ability to display as you can see the unactivated ghost of it in direct sunlight
hold ambient button and temp down button at the sametime till it resets
SOURCE: how to convert celsius temperature into fahrenheit ino c++?
Try using the simple mathematics;
- C: variable for the Celsius Temperature
- F: variable for the Fahrenheit Temperature
F=((9/5)*C)+32
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
SOURCE: logitech harmony advanced universal remote 550 display safe mode
remove the batteries from the remote
hold down to the number 2 key
as you are holding down to the number 2 key (do not let go of this number key) put the batteries back in
now remove the batteries again and put it back in again without pressing any buttons
if this does nto fix the issue
do a firmware upgrade
SOURCE: My Flea Taillight won't charge
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
Try the following, Cheers, Joseph
°F/°C CONVERTIBILITY - Press and hold SET TIME and
HOLD TEMP buttons until the temperature display is in
Celsius (°C). To display Fahrenheit (°F), repeat the pro-
cess. 5:30AM.)
Try the following. Cheers, Joseph
cess. 5:30AM.)
