Fujitsu FPCRC05 Remote Control Logo
Question about Fujitsu FPCRC05 Remote Control
I have a remote control unit Model : AR-RY7 fujitsu for a ductless airconditioner unit without a manual. I need to know how to program it.
Posted by janedeckenba on
Anonymous
    New Friend:
Jane,if you are still interested: Go to www.fujitsugeneral.com, click consumer, click service and parts, click manuals. Enter the model number of your indoor unit = small numbers on right hand side (e.g.,asu12rmlq and put plenty of paper in your printer. I had 19 sheets. Lots of luck. Bob
Posted on May 24, 2010
We have a Fujitsu split. remote ar-ry7 will turn on but unit doesnt respond. Read notes that say to reset remote. Dont know how. [email protected]
If you look at the remote you will find a small pin hole you will have to use a pin to reset the remote just put the pin in small and push and that resets
1helpful
Just do not understand it at all! can you help with model ar-ry7?
An inverter uses 12 volt DC current and inverts it to 110 volt AC current.
Basically, it will take 12 volts from a car battery, and change it to 110 volt current , same as in your house. What part are you having problems with?
10helpful
Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
6helpful
2answers
Replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
10helpful
5answers
Ductless Air Heat remote
I have the same remote(and the same issue), for a Fujitsu ASU9RMLQ system. I just found the link to the manual for my system, it has some instructions on how to use this remote:
http://www.fujitsugeneral.com/PDF_06/OperationManual/(OM)AOU24-36RML.pdf
3helpful
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Top Fujitsu Televison & Video Experts
Marvin
Marvin
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
