20 Most Recent Fujitsu Plasmavision P42VCA30EH 42 in. Television Questions & Answers
0answers
DIAGRAM P42VCA30EH 42
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
5/10/2016 5:29:10 AM • Fujitsu... • Answered on May 10, 2016
Why is screen not working? Red and green light both blinking?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
9/19/2014 1:20:29 PM • Fujitsu... • Answered on Sep 19, 2014
Remote control
If you wish to get its original remote control, contact the authorized service center for Funitsu. They only can provide you the original one. 0048,0038,0014,009,002,005 are the common setup codes to Fujitsu Brand TVs. If you're using a universal remote control now, check these codes to setup. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
10/28/2013 12:23:14 PM • Fujitsu... • Answered on Oct 28, 2013
How do you connect a fujitsu p42vca30eh to a BT
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
1/29/2012 8:04:38 PM • Fujitsu... • Answered on Jan 29, 2012
No sound coming from TV....recently
I think you are muting the the remote before you relocated...you need a remote to un-mute the sound of your TV...this cannot be done using the volume control in your TV unless you have the remote...if you loss the remote...buy a universal remote control
9/21/2011 12:32:34 PM • Fujitsu... • Answered on Sep 21, 2011
My fujitsu plasmavision works sometimes
A pleasant and good day!
The problem could be the power supply.
That problem is usually happen when the output voltage of the power supply got a voltage drop or fluctuation.
This is the procedure on how to fix that problem:
  1. Remove the back cover of your TV.
  2. Plug-in the power cord of your TV and power it ON to perform a voltage data or voltage check.
  3. Test the output voltage of the power supply.Use a multimeter (DC range) then check the 5vdc for the system and logic supply.
  4. If the 5vdc got a voltage drop when you power ON the TV.There's a leak or bulge on top capacitor on your power supply unit,replace it!
Like this:
I hope this solution will be helpful.Thank you and good luck.
6/2/2011 10:26:53 AM • Fujitsu... • Answered on Jun 02, 2011
Hi I bought a second
I also have the same problem. I think maybe getting an electrician out is our best bet. The cables and connections are so confusing. Hopefully you manage to sort your tv out. It may be an s-video cable that you need. I think I may try that.
Emma
3/2/2011 9:25:56 PM • Fujitsu... • Answered on Mar 02, 2011
I have a Fujitsu P50XHA10W. It shut down the other
I have the exact same problem - did you get your solved?
12/3/2010 11:13:53 PM • Fujitsu... • Answered on Dec 03, 2010
No sound coming out my plasmavison w p42vha31es
you need to plug the speakers into the back for sound.
8/22/2010 7:15:33 PM • Fujitsu... • Answered on Aug 22, 2010
I don't have a remote how do I turn up the volume?
Use the tv manual control button volume + - to turn up or down the volume.Try website like Remotes.com to buy an exact the original remote.
6/23/2010 1:53:33 AM • Fujitsu... • Answered on Jun 23, 2010
3answers
Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
2/27/2010 2:47:35 PM • Fujitsu... • Answered on Feb 27, 2010
My fujitju 42 plasmavision purchased from Harvey
Look carefully:Is this just behind the glass front? If so, somebody or something has leaned very heavily against the screen bending it inwards and fracturing the display layer. If no obvious signs of impact damage, spillage, corrosive sprays etc, try your warranty.
1/26/2010 2:25:10 PM • Fujitsu... • Answered on Jan 26, 2010
Help! My plasma screen is not displaying a
is inverter board problem, needs to be replaced, send to repair.
1/16/2010 2:23:40 PM • Fujitsu... • Answered on Jan 16, 2010
Fujitsu Plasmavision P42VCA30EH 42 in. Television Logo
48 questions posted
Top Fujitsu Televison & Video Experts
Joaquim Martins
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Televison & Video
Most Popular Question
  • Televison & Video
