Re: They forgot to turn my scanner on. My printer is a...
May need to install the Windows whatever Driver for the scanner.
A model number and make of the multi-function unit may assist in you getting a more accurate answer. Also how is it connected USB or Ethernet ?
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
-------------------------------------------------------------------------------- Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Turn the printer on.
Lift the lid that covers the print-mechanism.
In a few seconds, the cartridges will slide to a place where you can easily remove them, and insert a replacement cartridge.
Close the lid.
Hello The reboot of the pc along with a unplug of the printer should clear the printing. Do you have several printers listed to print to and did you print to the wrong one perhaps. You say the unit would print from the scanner which is sort of odd as well. My scanner prints but only cause it is hooked to the PC. there will be a large additional charge :-)
I have hp printer model R45
I got scanner error and printer asked me to turn power off and on. I turn the power off/on. Its about a month the Problem has started
Please HELP
Thanks
amin
Have you loaded the scanner driver software on your PC? Is the printer connected to the PC using a known good cable plugged into the proper receptacles? Is the scanner plugged into a known good power source? Is the scanner turned on? If you use one of the USB ports, your PC should automatically display NEW HARDWARE FOUND on your screen, and willl then ask if you want to install it using the SCANNER AND CAMERA INSTALLATION WIZARD.. You can also left click mouse on WINDOWS START, left click on CONTROL PANEL, and left click on the SCANNERS AND CAMERAS ICON. A new window should appear. Follow the instructions on this SCANNERS AND CAMERAS window, and you should be able to get your scanner working.
This answer is for the Toshiba eStudio 45 hi, im not 100% sure what you need help with so if you want to delete all the department codes on your copier but you do not know any of the current codes or the master code and need to change the master code follow these steps:
turn the copier off
while holding down 0 & 8 turn on.
key in 672 press start
press [INITIALIZE] (you might have to hit start if nothing happens i cannot remember)
this could take a min then you need to turn the copier off and back on.
you department codes should be cleared.
please let me know if i have helped or if i have not answered you question.
