It says that their are 317 songs on the player although only 45 will still only play on the sterio and this only happened over night.I've tried going through the settings and don't seem to get any where.
SOURCE: iTunes to MP3 player
your going to need a conversion program because most likely the itunes files are .acc and not.mp3 so find a nice little converter and enjoy
SOURCE: Phillips GoGear not turning on
my philips go gear sa5139 is not turning on. wen attached to the computer it shows that it is repairing but at last it show an unknown error occured and my gogear is still off.the computer is recognising it but in the of mp3 player it is showing nothing.i m charging it with external charger den also nothin happens. plz help me out.
SOURCE: I got a Philips gogear Vibe 4GB MP4 player today.
you just have to reset it again,,,,there's a reset button that needs you to pin a needle or something that pointy in that reset hole...
SOURCE: whenever i try to play
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Testimonial: "thanks"
SOURCE: my gogear vibe is frozen it wont work the screen
Please see this link which describes the steps to take when this player freezes up.
Please remember to leave a vote for the solution if it helps.
Many thanks. Link is here.
