itunes uses an M4A file format. You will have to download a file converter, then convert it to mp3. try www.cnet.com and search for audio converter. Lots of free software to choose from.
Charge your Philips GoGear ViBE for at least three hours before turning it on.
Insert the small end of your
mini USB cable into your GoGear ViBE. Insert the other end of this cable
into one of your computer's USB ports. Turn your GoGear ViBE on by
pressing and holding the "Power" button for two seconds.
Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
Open "Computer" from the "Start"
menu and locate the GoViBE icon to make sure it has been successfully
connected to your computer.
5
Navigate to your music files. If
you're unsure about their location, start by looking in the "Music"
folder under the "Start" menu.
6
Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
7
Right-click the USB icon with
the green arrow, located in your taskbar, to disconnect your device.
Click "Safely Remove hardware," then wait until your computer confirms
that it's safe to remove the device. Disconnect the USB cable from both
your computer and your GoGear ViBE.
8
Select the musical note icon
from the main menu of your GoGear ViBE to open your music files.
Navigate to the sub-folders section, and select a song from either the
artist, album, track list or genre. Press the "Play/Pause" button to
begin playing a song
Thats becausethe tunes that you download are probably Itunes, and Itunes has a DRM on all movies/music/music videos.
What that means is the music will only work when they are in Itunes or are on other Apple products,like Ipad,Ipod,etc.
You will need to convert those songs from ACC to MP3 or WMA before they will play on your MP3 player. You can get a free file converter at the following webpage: http://formatoz.com/ Please take time to rate me
MP3 players can only play music files in mp3 file format.
You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player. You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Your VIBE is MP3 format and iTunes uses a format that only apple products recognize. Even if you download to iTunes on your computer, you can't change the file extension to load it on an MP3 player.
Sorry iTunes does not allow non-iPod devices to sync with iTunes. However, if you download something called Double Twist, you can put the songs that you have in iTunes onto your Gogear. Double Twist pulls your music from iTunes and does all the necessary file conversion and it's really easy to use, you should give it a try.
Hope this helps!
Your formating for your songs are fine. The Phillps GoGear uses mpeg as well as long as they are not AAC formating. You need to open Windows Media Player and click on the Library tab and then Add to Library. I'd recommend using the advanced tab when the window pops up. You can then tell WMP exactally where the songs are at in the itunes folder. You'll want to find out where they are at first. It should load them onto WMP from there and then you can move them to you GoGear. Enjoy.
