I tryed reseting it, i iven pulled the brewgroup out, and put something inside to keep the microswitch on to detect brewgroup in it, and iven so the machine moves a bit than always says brewunit blocked not missing - just to make sure. And another thing, the engine that should move the brewunit moves really slow, compaired to when it was working, when it used to make fast and loud moves. Now you can bearly hear it, and moves really really slow. I also tryed checking all the cable connectionts on the motherboard, and everything is inserted fine. What can it be? please help.
At the main board there are two transistor on a aluminum.The one is small and the other one is bigger. The big one is usually tip33c or bdxxx if that is damaged group turns slowly.
Testimonial: "I have fixed it , 2 days ago. And you were right, that was it, the Tip 33C. I replaced it with BD245C, and i also replaced a zener diode next to it. It works now. Thank you for support."
SOURCE: dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
SOURCE: Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
SOURCE: Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
SOURCE: I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
SOURCE: Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
