20 Most Recent Saeco Magic Comfort Plus Espresso Machine Questions & Answers
3answers
After emptying the dredge drawer and replacing it, the unit still says "Dredgedrawer Missing"
The sensor that detects the presence of dredge drawer is not closing. Locate it and fix it or just jump the wiring to the sensor.
8/16/2019 5:19:28 PM • Saeco Magic... • Answered on Aug 16, 2019
Saeco Magic problem. The magnet rises when I fill the water tank off the machine but, it drops as soon as I make a cup of coffee. To clear, I have to remove the tank and reset the machine. Any help?
hi, what do you mean by "it drops" ? If it doesn't float anymore, you have to replace it. Remove the top cover of the small tube where the magnet floats, replace the floating magnet and replace the cover. If the cover doesn't seat properly, glue it with a drop of silicone so you can remove it next time. If the magnet floats but is not recognized by the inside detector (the small white block you can see inside the machine, in front of the magnet), it is probably because the magnetism has fainted with time. Replace it with a new one. Hope that helps. M.
5/15/2016 9:03:15 PM • Saeco Magic... • Answered on May 15, 2016
Grinder works fine. Water pump sounds normal but no water flow when in rinse mode, brewing coffee or in hot water dispense mode. Something is clogged???
Run a simple cleaner through your system without coffee. Pour in white vinegar 4:1 ration. Brew this maybe up to 3 times. Should clean your clog.
5/1/2016 10:05:41 PM • Saeco Magic... • Answered on May 01, 2016
Display on Saeco Magic Comfort+
Hi
This is usually a magnet in the water tank or sensor inside the machine. First do you have the grey magnet in the water tank? If no magnet in the tank, that is the problem. The magnet floats when the tank is full and sinks when its empty. It sends a flux signal to the sensor inside the machine. If the sensor is bad inside it doesn't pick up the flux field and you get the "water tank empty" display.
10/13/2015 1:05:05 AM • Saeco Magic... • Answered on Oct 13, 2015
Saeco magic comfort plus - brew unit miss??
Check the micro switch that the brew unit hit when it enters the machine. Sometimes the lever arm on the switch breaks off, and the switch will no longer work. Click the link for a picture of the micro switch. Micro switch for saeco and gaggia machines
7/2/2015 10:58:40 PM • Saeco Magic... • Answered on Jul 02, 2015
2answers
What does an error message "venilate" means
Means it is wet inside
6/3/2015 3:13:44 AM • Saeco Magic... • Answered on Jun 03, 2015
How do you descale
Yes vinegar or special liquid for descaling. The same result. Put the liquid into watertank,then rinse trought hot water knob about 10 seconds,then turn off machine for 5 minutes,rinse rest of liquid and then fill watertank with fresh water and rinsing again all water from the tank.
4/26/2015 4:39:07 PM • Saeco Magic... • Answered on Apr 26, 2015
2answers
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
4/15/2015 7:25:02 PM • Saeco Magic... • Answered on Apr 15, 2015
3answers
Put water in coffee grinder
No, let it completely dry out. Better yet, use forced air to dry it out such as a hair dryer or compressed air.
2/14/2015 11:12:04 PM • Saeco Magic... • Answered on Feb 14, 2015
How do I clean the grinding mechanism?
Cleaning the grinding mechanism can be seen on the following page link: Maintenance of Espresso machines La Pavoni Espresso Machines and Parts When you open this page scroll down to the heading section on the page, "Grinder cleaning and repairs". You will find download file for illustrated steps to fix the cleacing of grinder. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
2/5/2015 12:48:39 PM • Saeco Magic... • Answered on Feb 05, 2015
How do I unblock brew unit from Saeco Magic Comfort Plus?
unscrew where is the arrow and take off the brew unit(the block). 2f695735-a536-451d-bb80-581676922785.jpg
9/15/2014 7:36:23 PM • Saeco Magic... • Answered on Sep 15, 2014
0answers
I accidentally put water in the grinder will it dry out
no,will not dry .You have to take off the beans canister and get out the grinder knife to clean it.
8/11/2014 7:05:57 PM • Saeco Magic... • Answered on Aug 11, 2014
0answers
No power
Be the first to answer 7/7/2014 3:06:39 AM • Saeco Magic... • Posted on Jul 07, 2014Be the first to answer
Saeco Magic Comfort Plus Espresso Machine Logo
228 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Muzahura Frank
David Shaub
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Saeco Coffee Makers & Espresso...
  • Saeco Coffee Makers & Espresso...
Most Popular Question
get dreg drawer back in place because
  • Coffee Makers & Espresso Machines
