SOURCE: No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
SOURCE: sony dcr hc32 LCD not working
the flexwire of the lcd monitor of your camera is already cut.....it have to repair or replace now cause that wire is very small and only skilled technician can repaired it...lot of our customer it is the common problem of there camera that why in our shop we modified that and became more durable than the original wire....
SOURCE: LCD Side Screen Display Not Displaying
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
SOURCE: Sony Mini camcorder DCR-HC21 problem with LCD and viewfinder. need help ASAP!!
i have the same problem,i opened the camera, i have taken out the flexible cable, its broken at the hinge...it looks like a bad design of the cable is the reason.
the cable is 1cm in width and at one point when it passes through the
hinge the cable is split into two with .5cm width each. one cable is cut at the pt where it enters the hinge, this cable is stretched to fit into the hinge, guess thats why it broke so soon...
It would be great if some1 can guide on from where and how to get this cable..
Anand
SOURCE: Samsung Digital Camcorder VP-D351
hi..Please to pass on the remedy..I had this two weeks ago.. lcd ribbon is brocken.. breaks over time with being opened and closed.. Part available form partmaster.co.uk.. part no..SAMAD9706489A.. lcd fpc ***. easy to replce ..take you time and try yourself.. if i can help with instructions [email protected].. cost of ribon £11.49.. GOOD LUCK STEF.
