20 Most Recent JVC GC-XA1 ADIXXION Action Camcorder Lens Protector for ADIXXION Action Camcorder Flexible Mount for ADIXXION Action Camcorder Twin Shooting Mount for ADIXXION Action Camcorder Questions & Answers
3answers
Play back on jvc video movie GR-A1E distorted
It is possible that the heads in your JVC video camera need cleaning, especially if the playback picture looks distorted and similar to a VHS tape played on a player with dirty heads. Dirty or worn-out heads can cause playback issues, including poor picture quality, distorted images, and tracking problems. To clean the heads in your JVC video camera, you can try the following steps:
  1. Purchase a head cleaning cassette: You can find head cleaning cassettes online or in electronics stores. Make sure to get one that is compatible with your JVC video camera.
  2. Insert the cleaning cassette: Open the tape compartment on your JVC video camera and insert the head cleaning cassette. Close the tape compartment.
  3. Run the cleaning tape: Press the play button on your JVC video camera to run the cleaning tape. The cleaning tape will clean the video heads as it plays.
  4. Eject the cleaning tape: Once the cleaning tape has finished playing, eject it from your JVC video camera.
  5. Test your tapes: Try playing your tapes again to see if the picture quality has improved.
If cleaning the heads does not solve the problem, it is possible that there is a more serious issue with your JVC video camera.
3/18/2023 9:07:17 PM • JVC Video... • Answered on Mar 18, 2023
2answers
How to fix Jvc GR-D239E safemode 06?
Safemode 06 on JVC camcorders usually indicates a problem with the tape transport mechanism. It could be a mechanical issue or an electrical issue. It's possible that the black rubber you found inside the camera was a part of the tape transport mechanism that came loose or broke off. It's also possible that there is some debris or dirt stuck in the tape transport mechanism, preventing it from functioning properly. One thing you can try is to clean the tape transport mechanism with a soft brush or compressed air. Be careful not to touch any of the delicate parts inside the camera. You can also try using a different tape to see if the problem is with the tape itself. If cleaning the tape transport mechanism and using a different tape doesn't solve the problem, it may be necessary to take the camera to a professional for repair. They will be able to diagnose the issue more accurately and determine if any parts need to be replaced.
3/18/2023 8:18:17 PM • JVC Video... • Answered on Mar 18, 2023
I have a JVC GR - 65 moviemaker. when I try to export the footage from my tapes to digital. the footage goes all glitchy and stutters not being able to see a clear view of the video any ideas ?
It's possible that the issue is related to a problem with the tape itself, the camcorder's playback mechanism, or the connection between the camcorder and the device you're using to digitize the footage. Here are a few things you can try to troubleshoot the issue:
  1. Clean the camcorder's playback head: Over time, the playback head on your camcorder can get dirty or clogged, which can cause problems when you're trying to digitize your footage. You can clean the playback head using a cleaning cassette or by using a soft cloth and rubbing alcohol to gently clean the head. Be sure to follow the instructions in your camcorder's manual.
  2. Check the condition of the tape: Your footage may be glitchy or stuttering because of a problem with the tape itself. Check the tape for any damage, such as wrinkles, tears, or warping. If you notice any damage, you may need to try a different tape.
  3. Use a different playback device: It's possible that the issue is related to the connection between your camcorder and the device you're using to digitize the footage. Try using a different device, such as a different computer or a different capture card, to see if that helps.
  4. Check your capture settings: Make sure that the settings on the device you're using to capture the footage are set correctly. Check the resolution, frame rate, and other settings to make sure they match the settings on the camcorder.
  5. Try a different cable: The cable you're using to connect your camcorder to your capture device may be faulty. Try using a different cable to see if that helps.
If none of these steps resolve the issue, it may be worth consulting with a professional technician who can diagnose and repair the issue with your camcorder or provide other troubleshooting options.
3/3/2023 3:09:41 PM • JVC Video... • Answered on Mar 03, 2023
Using vidbox to transfer dv to my 2015 IMAC tapes record but no audio - what do i do
It's possible that the DV clean you performed on your JVC camcorder has affected the audio during playback on your iMac. Here are some steps you can try to troubleshoot the issue:
  1. Check the audio settings on your iMac: Make sure that the audio settings on your iMac are configured correctly. Check that the volume is turned up and that the audio output is set to the correct device.
  2. Check the audio cable: Make sure that the audio cable you are using to connect your JVC camcorder to your iMac is not damaged and is securely plugged in on both ends.
  3. Try a different audio cable: If the audio cable is damaged or faulty, try using a different one to see if that resolves the issue.
  4. Check the audio on the original tapes: Check the audio on the original tapes to see if the issue is present there as well. If the audio is present on the tapes but not on the copied files on your iMac, then the issue may be with the copying process or the file format.
  5. Check the file format: Make sure that the file format you are using to copy the video files supports audio. Some file formats, such as MP4, may not support audio.
  6. Try a different video player: Try playing the copied video files on a different video player to see if the audio works. If it does, then the issue may be with the video player you are using on your iMac.
If none of these steps resolve the issue, it's possible that the DV clean process on your JVC camcorder may have damaged the audio during playback.
2/22/2023 9:35:18 AM • JVC Video... • Answered on Feb 22, 2023
JVC Everio GZ-MG21U has a blank screen. The LCD works but not when trying to record
If the LCD screen on your JVC Everio GZ-MG21U works but goes blank when you try to record, it could indicate a problem with the camera's image sensor or the connection between the sensor and the LCD screen. This can be caused by a variety of issues, including a faulty sensor or a damaged cable. To troubleshoot this issue, you can try resetting the camera to its default settings, making sure that the battery is fully charged, and checking the camera's cable connections. If these steps do not resolve the problem, it may be necessary to have the camera serviced by a professional technician.
2/14/2023 6:13:00 AM • JVC Video... • Answered on Feb 14, 2023
JVC GZ-HM30 HD Everio Camcorder. Can't transfer videos to my Everio GZ-HM30SU camera.
Question edited for clarity. Some help in the link although the software is not there. Your father should have had a disc somewhere. Contact JVC direct. https://www.google.com/search?q=+JVC+Everio+GZ-HM30SU+camera+software ..
1/4/2023 2:58:15 AM • JVC Video... • Answered on Jan 04, 2023
How to remove the icons on the JVC digital camera GZ MG 37 AH
To remove icons from the display screen on your JVC digital camera model GZ MG 37 AH, you will need to follow the specific instructions for your camera model. Here are the general steps you can follow to hide or remove icons from the display screen:
  1. Press the Menu button on your camera to access the main menu.
  2. Use the arrow buttons to navigate to the "Display" or "Setup" menu.
  3. Locate the option for hiding or removing icons from the display screen. This option may be called "Icon Display," "Screen Display," or something similar.
  4. Use the arrow buttons to select the option for hiding or removing icons, and then press the OK button to confirm your selection.
  5. Use the arrow buttons to navigate through the available options for hiding or removing icons. You may have the option to hide all icons, hide selected icons, or show all icons.
  6. Select the option that best meets your needs and press the OK button to confirm your selection.
  7. Press the Menu button to exit the menu and return to the normal display screen.
1/2/2023 6:18:14 PM • JVC Video... • Answered on Jan 02, 2023
Wherecan I find a driver for JVC GR DX 37
1. JVC GR DX 37 drivers can be found on the JVC website. You can find the drivers by searching for your specific model number on the website. If you can't find the drivers on the website, you can try contacting JVC customer support. 2. Drivers can also be found on third-party websites. There are many websites that offer drivers for JVC GR DX 37. However, not all of these websites are reliable. You should only download drivers from websites that you trust. 3. If you can't find a driver for your JVC GR DX 37, you can try using a driver update tool. Driver update tools are software programs that can find and download drivers for you. They can be found on the websites of various hardware manufacturers. 4. If you still can't find a driver for your JVC GR DX 37, you can contact JVC customer support. JVC customer support can help you find the drivers you need.
11/18/2022 1:16:41 PM • JVC Video... • Answered on Nov 18, 2022
6answers
File format is .mts and my computer doesn't read
Maybe you can try to use Leawo MTS Converter.
Leawo MTS/M2TS Converter lets you convert MTS and M2TS videos to various formats, e.g. AVI, MP4, WMV, MOV, MPG, FLV, and RMVB, to meet different demands of edit, playback and application. This powerful MTS/M2TS video converter supports videos recorded by Sony Hard Drive Camcorders and other recording equipments. It supports up to 1080p video resolution with synchronization of audio and video upon any format output.
You can free download it in here: http://www.leawo.com/mts-converter/
8/31/2022 3:53:02 AM • JVC Video... • Answered on Aug 31, 2022
How can i fix my handy camera?
bad batteries, no 2005 , no 17 year old battery lasted this long, ever. they are bad. that old. found it and grandads attic.? page 2 Use the JVC BN-V408U/V416U/V428U battery packs and, to recharge them or supply power to the camcorder from an AC outlet Lithium-Ion Batteries 3 different sized packs for it, modular and custom to this cam. https://www.manualslib.com/manual/82252/Jvc-Gr-D225.html?page=7&term=lith&selected=1#manual
8/29/2022 4:59:25 PM • JVC Video... • Answered on Aug 29, 2022
JVC GRD27OU Camera. I HAVE JVC camera that won't charge.
Question edited a bit for clarity and remove some SHOUTING!! Question moved form Computers to JVC Cameras. It appears to be a known issue. Test the output of the charger with a multimeter. It may be that the internal battery has failed and needs replacing. https://www.google.com/search?q=jvc+grd27ou+won%27t+charge ..
3/2/2022 12:47:06 AM • JVC Video... • Answered on Mar 02, 2022
JVC GR-AX230U camcorder gives me an E02 error code and immediately turns off.
This camcorder was obsolete in 2003 it is now 2021 ... there is no support for repairs.
2/27/2022 5:06:41 AM • JVC Video... • Answered on Feb 27, 2022
Model GR-D25OU. What does code 6 mean?
See pages 40-41 of the manual
2/12/2022 8:57:52 PM • JVC Video... • Answered on Feb 12, 2022
I have a JVC GR DV800U camcorder in NTSC format. Can I change that to play PAL tapes?
Short answer - no Long answer - no you cannot. Transfer the files to your computer.
12/11/2021 7:33:49 AM • JVC Video... • Answered on Dec 11, 2021
How do I format in camera of JVC Everio camcorder?
For what model?
11/9/2021 12:39:30 PM • JVC Video... • Answered on Nov 09, 2021
JVC GC-XA1 ADIXXION Action Camcorder Lens Protector for ADIXXION Action Camcorder Flexible Mount for ADIXXION Action Camcorder Twin Shooting Mount for ADIXXION Action Camcorder Logo
0 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marco Avila
Marco Avila
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
JVC Video Cameras
  • JVC Video Cameras
Most Popular Question
fix jvc gr d239e safemode 06
  • Video Cameras
