Question about Ricoh Office Equipment & Supplies
Sc 558 error code on Ricoh Pro C720
When the machine warms up it comes up with error code SC 558 can some one help me with this code please or direct me how to clear this code
Posted by jc1print on
Ken Filoso
SC558 is a Oil supply motor error The machine detects a motor rotation error for 5 seconds after the oil
supply motor has rotated for 5 seconds. ?? Oil supply motor defective
?? Oil supply unit defective
1. Replace the oil supply motor.
2. Replace the oil supply unit.
Posted on Feb 08, 2015
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Posted on Oct 27, 2008
Anonymous
  • 126 Answers
SOURCE: machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Posted on Jan 20, 2009
Anonymous
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
2answers
J'ai une ricoh mp c5501qu iaffiche sc819
North American website, we speak English :>)
I have a ricoh mp c5501 which displays sc819
Google Translate ici.
https://translate.google.ca/?sl=auto&tl=en&text=J%27ai%20une%20ricoh%20mp%20c5501qu%20iaffiche%20sc819&op=translate
The answer is NOT good!
AFICIO MP C551 SC 819 ( 5348 0x5554444F ) - Copytechnet
https://www.copytechnet.com > forums > 126200-aficio...
Jan. 13, 2018 - SC 819 is a fatal kernel error. Either the controller and possibly other boards were blown by the power surge or the components you replaced on ...
Ricoh Aficio 2035 SC819 Error Code - Copytechnet
Mar. 31, 2010
Error Code Ricoh MP5002 SC 819-00 - Copytechnet.com
Apr. 13, 2016
Error Code SC-819 MP 5000 - Copytechnet.com
Oct. 4, 2013
Thread: error SC 819 - Copytechnet.com
Mar. 30, 2017
More results from www.copytechnet.com
SOLVED: What is sc819 for ricoh aficio c4501 - Fixya
https://www.fixya.com > ... > Ricoh
Sep. 1, 2019 - Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first ...
SOLVED: My machine ricoh mp c2352sp displays SC 819. I
Nov. 18, 2019
SOLVED: My ricoh aficio is showing sc819 - Fixya
Jan. 24, 2018
Ricoh mp 2550 error code sc 819 how to solve this problem
Nov. 21, 2019
SOLVED: Sc819 trouble/error in ricoh aficio mp5000. any - Fixya
Jun. 2, 2011
More results from www.fixya.com
Ricoh Aficio 480W - SC819 - PrintCopy .info
https://printcopy.info > brand=Ricoh > code=SC819
Ricoh Aficio 480W · Code: SC819 · Description: Fatal kernel error. Due to a control error, a RAM overflow occurred during system processing. One of the following ...
Ricoh 2018D error code sc 552
Do following steps
1. Yellow cancel
2. 107
3. Hold down red clear/cancel
Machine will beep.
Select 1 - copier sp
Type 5# 810# (fuser sc reset)
Select execute and restart the machine.
If code re-appears you have a faulty fuser lamp or thermostat.
If machine works for a while or at least tries to warm up, you have a faulty thermistor.
That is an oil supply pump error for the fuser. It probably needs to be replaced.
2answers
HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
3answers
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil [email protected]
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
1helpful
2answers
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
2answers
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
7helpful
3answers
Ricoh aficio 2027
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
