When the machine warms up it comes up with error code SC 558 can some one help me with this code please or direct me how to clear this code
That is an oil supply pump error for the fuser. It probably needs to be replaced.
Posted on Feb 03, 2015
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before. Check the connections in the laser unit.
Posted on Oct 27, 2008
SOURCE: machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Posted on Jan 20, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
