Refrigerators Logo
A
Anonymous Posted on Oct 05, 2014
F & P N500B Fridge Freezer Not working at all
Model N500B, just not working
Brad Goodale
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 106 Answers
  • Posted on Jan 17, 2016
Brad Goodale
Expert
Level 2:
New Friend:
Cheetah:
Answers
106
Questions
Helped
32576
Points
168
Gas problem not worth reparing if this is the case.
5 Related Answers
Anonymous
  • Posted on Dec 08, 2009
SOURCE: We hace a F & P upside down unit model n500b
Problem solved, a search on troubleshooting found a common fault, a seized fan, replaced at minimal cost.
douglas smith
  • 1462 Answers
  • Posted on Sep 30, 2008
SOURCE: I have a Fisher &
using a hairdryer is ok. don't let water drip on it and don't point too close to plastics
ice build up on fridge wall can be due to:
short of gas
partial blockage in sealed system
compressor starting to fail
stat switchback temp wrong
insulation failure
tomsat69
tom wright
  • 219 Answers
  • Posted on May 10, 2009
SOURCE: lights on but fridge not working on Fisher and Paykel N500B
There could be a few reason 1 you may have a faulty temp control switch try taping it to see if it kicks on.If that does not work remove the compressor start switch shake it to hear any noise like pieces burnt in it.If not try advancing your defrost timer to see it kicks on also.If those do not work you may have an elecrical problem.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Oct 28, 2009
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Anonymous
  • 3600 Answers
  • Posted on Jan 24, 2010
SOURCE: I am looking for crisper bins for a F & P N500B fridge
Here is a parts store you can call 6 days a week and order any part you need I did not find that model listed but you can talk and find the number. here it is and hope this helps thanks for using fix-ya.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=E522B
My N500B fridge freezer works in freezer section, fridge stays at 10c. have found fan in freezer is not spinning and when inspecting it is cought against body of motor. Can i cut off part of wings?
It is best not to cut the fan blades if it can be avoided - best to cure the original fault if you can.
If you need to trim the blades it is very important to remove exactly the same amount from each blade to maintain the balance. The weight might seem insignificant but over time even a tiny imbalance can cause an increased noise level.
11helpful
2answers
Fisher and Paykel N500B fridge not cooling but lights on
if not humming at all then i would say a new thermostat should fix the problem
Lights on but fridge not working on Fisher and Paykel N500B
3helpful
I have a Fisher & Paykel fridge/freezer model N500B a CFC model with the freezer below the fridge. We have started to get a frost biuld up at the top of the back wall of the fridge compartment. A...
short of gas
insulation failure
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
