Question about Refrigerators
Fisher and Paykel N500B fridge freezer. Freezer not freezing
Fridge is cold and appears to be working normally.
Freezer is cold, but not freezing (ice trays are still liquid)
  • 1 more comment
  • Anonymous Mar 14, 2014
    I have a whirlpool fridge freezer the fridge part keeps freezing food and liquids
  • Anonymous Mar 26, 2014
    water not cold
  • Anonymous Mar 30, 2014
    fisher and paykel fridge/freezer, the freezer appears to be working fine, however i do not seem to be able to get the fridge to go any colder
Charles T Nevin
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 28, 2009
Anonymous
    New Friend:
I had a similar problem on the same model. Ice creams were soft & frozen food not ice cold. I opened the freezer. Removed the food & noticed the evaporator fan at the back was not turning. This is the likely cause of poor cooling in the freezer. I got it running by turning the fan with a screwdriver but replaced the fan soon after!!!
Posted on Jan 09, 2010
Fisher and Paykel N500 B fridge vegetables in vege tray are frozen
it sounds like your thermostat is not working it may need to be replaced.
May 16, 2014 | Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Hi, I have a fisher and paykel fridge for almost 3 years.The problem is that the ice cube maker stop working. I have check all the things that are mention in the fridge guide, water supply is fine, the ice...
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
Jan 29, 2011 | Fisher and Paykel Active Smart E522B...
I have a Fisher & Paykel fridge/freezer model N500B a CFC model with the freezer below the fridge. We have started to get a frost biuld up at the top of the back wall of the fridge compartment. A...
using a hairdryer is ok. don't let water drip on it and don't point too close to plastics
ice build up on fridge wall can be due to:
short of gas
partial blockage in sealed system
compressor starting to fail
stat switchback temp wrong
insulation failure
Sep 30, 2008 | Refrigerators
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
3,365 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
