Posted this just now, but wrong model appeared in title so I am repeating problem posting. Fisher and Paykel N500B - fridge top, freezer bottom.Fridge light is on, but cooling has stopped. Not sure if freezer has stopped too as still cold inside but could be just slower warming up than the fridge section. Humming sound has ceased at back of fridge (usually on). Could this be a fuse problem? Thanks
SOURCE: top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
SOURCE: uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
SOURCE: lights on but fridge not working on Fisher and Paykel N500B
There could be a few reason 1 you may have a faulty temp control switch try taping it to see if it kicks on.If that does not work remove the compressor start switch shake it to hear any noise like pieces burnt in it.If not try advancing your defrost timer to see it kicks on also.If those do not work you may have an elecrical problem.
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
I had a similar problem on the same model. Ice creams were soft & frozen food not ice cold. I opened the freezer. Removed the food & noticed the evaporator fan at the back was not turning. This is the likely cause of poor cooling in the freezer. I got it running by turning the fan with a screwdriver but replaced the fan soon after!!!
SOURCE: I am looking for crisper bins for a F & P N500B fridge
Here is a parts store you can call 6 days a week and order any part you need I did not find that model listed but you can talk and find the number. here it is and hope this helps thanks for using fix-ya.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
I have the same fridge and had a problem with the freezer yesterday when it was iced over the fan was still going defrosted with a hair dry problem went away.My fridge is not as cold as it used to be sounds like we have the same problem
