Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fisher & Paykel Fridge Freezer E402B beeping when door closed
Beeping when door shut - The temperature gauge light is flashing constantly. Even checking the settings set at normal for the fridge the light contues to flash. The freezer is okay but the food in the fridge is either warm or frozen. The highest shelves are warm, the lower shelves freeze the food including the lowest shelf on the fridge door where milk is stored. This is happening on a daily basis. I have to push the temp button inside the fridge to get it to stop beeping when it goes off on it's own. HELP!
Posted by jayne_watt1 on
  • 1 more comment
  • Anonymous Mar 25, 2014
    after beeping while door closed i tried to adjust temp control but it seems that it is not as cold as it should be and things are thawing out in freezer
  • HARNEET HONEY
    HARNEET HONEY Apr 27, 2015
    hi...i have same problem with my fridge ...did u find out what was the problem...?thanks
  • Deborah
    Deborah Jun 16, 2017
    I have a similar problem. No beeping but the temperature lights flashing.I have done a re-set but its the same. Any ideas anyone please? Thanks
Anonymous
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
2answers
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Hi, I have fisher and paykel E522BLX bottom freezer fridge. It is making beeping sound sometimes when I open the door. It also has green light flashing on the control panel all the time. Both fridge and...
beeping when door is open is one of its features the flashing light means someone has tried to set something and not completed the selection just try pushing one of the buttonstill it stops
4helpful
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
1helpful
3answers
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
Top Fisher and Paykel Refrigerators Experts
Dan Webster
Dan Webster
Gil Shultz
Jay Finke
Jay Finke
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
