SOURCE: HP deskjet printer compatible ink cartridges
They will not work. Although they may look similiar and may even fit into the cartridge holder. The internal circuitry is different and will not be read correctly by the printer. If they are all brand new or unopened, there is always ebay.
Daniel (rydf)
SOURCE: Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Are your sure the cartridge is compatible with the printer...? normally third party cartridge give this type problem...
Follow this link,it may be help you...http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01091133&lc=en&product=1141647
Otherwise you should contact with manufacturer company of your printer.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
