20 Most Recent HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX Questions & Answers
make sure you have removed an orange small plastic piece if u don't remove printer will detect it as a Supply memory error
hp laserjet pro m1213nf mfp driver Software downloads Hp Drivers
HP LaserJet Pro... | Answered on Feb 26, 2018
The 59 error indicates a motor is not functioning. check all the wiring to make sure you did not leave something disconnected after you fixed the power supply.
HP LaserJet Pro... | Answered on Feb 16, 2017
From the HP manual.
51.XX Error, Turn off then on
Description
The product has experienced an internal hardware error.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
If the message persists contact HP support.
From PrinterTechs.com
51.X PRINTER ERROR
A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
HP LaserJet Pro... | Answered on Oct 08, 2016
Try turn printer off - hold down right arrow and cancel keys...Turn printer on (keepholding keys down) - when 'perm memory init' displays, release keys. Allow printer to 'boot'..
HP LaserJet Pro... | Answered on Jul 12, 2016
10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
HP LaserJet Pro... | Answered on Feb 24, 2015
have 59.3 error on my printer hp laserjet pro 300 color what to do??
HP LaserJet Pro... | Answered on Mar 20, 2014
59.3 indicates the fuser motor is not starting up.
This usually means the fuser motor needs replaced.
Part Number RM1-8609-000CN
HP LaserJet Pro... | Answered on Mar 16, 2014
Hard Reset:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till warm-up period finishes and the printer is idle.
HP Office... | Answered 2 hours ago
Change both cartridges, reset the printer and try again.
HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX Logo
Popular Tags
23 questions posted
Ekse
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
fix 59 3 error
  • Office Equipment & Supplies
