Epson Stylus Photo R220 InkJet Printer Logo
A
Anonymous Posted on Aug 27, 2014
When the red light flashes, in Windows 8 the color chat does not come up. How can I tell which color is empty?
2answers
Flatbed printer with Epson L800 printhead Red Light Flashing
What is the error that appear in the printer status on your computer?
Epson 7010 all lights flashing & won't print
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed
·Check empty or damaged ink cartridge
·Clean the dirty print head or replace missing or failed print head
·Read the steps to fix the Epson printer lights blinking error.
Sd card full
try formatting to FAT32 or NTFS
2answers
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
1helpful
The Red light is on and the back of the printer is far too hot
if the red light is on and one of the colors light is on too.
that means that that toner is empty. if the main light is blinking, it means that that toner is low.
please check your user manual on page 6-8
thanks adi
Do I need to replace my empty tri-color cartridge just for the brand new black one to work? My light keeps flashing and nothing will print.
Well you need tio give us a bit morte informationm.
Is the flashing light telling you that the multi-colored cartridge is in fact empty?
Are you using re-filled or third party cartridges? If so, then the printer will block the usage of thes types of cartridges because of the damage they can potenialy do to the print mechinisim.
Don
6helpful
3answers
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
6helpful
2answers
Kyocera fS-920KX. Not printing
YBC (/\)
'99 Mercury Cougar - Seatbelt light flashes 8 times in pattern
? I wounder what color is your lamp - red or yellow (amber) and just so you know most parts stores now days can tell what a code is with out charging a dime to you.
11helpful
2answers
Kyocera Ecosys FS 920
YBC (/\)
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
