20 Most Recent Kyocera FS-920 Laser Printer Questions & Answers
call 239 939 5383 they can try to locate one for you and quote you a price for a new one
Kyocera FS-920... | Answered on Jan 03, 2019
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
Kyocera FS-920... | Answered on Feb 09, 2018
old printer not really worth fixing
Kyocera FS-920... | Answered on Sep 08, 2017
Clear the print que. Sounds like you have a print job in the que that has a European paper size. Example A4. U.S.A. useS 8.5x11 or letter or letter (r)
Kyocera FS-920... | Answered on Jan 03, 2015
It sounds like the fuser heater has failed.
Kyocera FS-920... | Answered on Dec 10, 2014
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Vertical lines? How many pages have you printed? Check the counter and then answer to my post. Maybe you will need to replace the MK. Check the surface of optical cylinder for scratches. However, if the MK is not at the end of his life, and the cylinder surface is not damaged, you will need to clean the charge roller and then to execute an Drum Refresh from Service submenu. This is the most frecvent problem that I meet, related to vertical lines. There could be other bad components, but you will need to check first the drum unit.
Kyocera FS-920... | Answered on Jun 02, 2014
driver issue. download latest driver and update printer firmware
Kyocera FS-920... | Answered on Jan 02, 2014
It jamming from cassette one ,if you remove the cassette look inside where the cassette came out of and you will see two grey/blanch roller give them a good clean with a damp cloth and your problem should be fixed
Kyocera FS-920... | Answered on Nov 12, 2013
It might be more interesting for you to get a new machine. If you shop carefully you may get a better one for a fraction of what you are asked to pay to have the old one repaired.
Kyocera FS-920... | Answered on Oct 07, 2013
Kyocera FS-920 Laser Printer Logo
61 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
kyocera fs 920 7 years old maybe 4 000
  • Office Equipment & Supplies
