After replacing drain pump, my washer ran almost a full cycle, stopped during the last rinse wont run now. It turns on but doesn't run and has no error code
SOURCE: code OE water is not being drained out
You may have a broken or plugged drain pump and needs to be diagnosed by a qualified LG technician.
SOURCE: LG Washer LE Error
I replaced my hall effect sensor about two weeks ago and just hooked the machine back up a few dags ago. My wife ran about 5 loads through it and it shut down with the LE code again!!! I ordered the part from MCM Electronics and they are sending me a replacement part for free since the first one lasted only a day. Hopefully this is the last time I have to replace this part. It would be great if someone knew how to bench test one of those sensors so I could know for sure if my first one is really defective. I always have a hard time believing when a new part fails so soon.
SOURCE: my lg washer will not go into spin cycle.
I had the same problem. I found a water leak on the water valves at the back on the unit. This leak dripped on a wire that lead back to the ball sensor. The water was causing the computer to interpret a "unbalanced error". I suggest that the valves have a design defect that caused them to start leaking. After I discovered that my local appliance parts stores is NOT allowed to carry LG parts. I was very upset. I removed the ALL of the valves, cleaned them and applied a thin coating of silicon around the plastic solenoid shell, reassembled and I have no more leaks. I also cleaned the "ball" sensor to get rid on any moisture. Afterwards my wife was able to do 8 loads and me twice.
SOURCE: LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
SOURCE: "FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
Iām happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
