Will not read DVDs or CDs or USBs, it says reading and then tray just opens up and no error message, FM radio and TV input are still working ok.
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
SOURCE: tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
SOURCE: Combo drive CD not reading, but DVD ok
it may have dual laser and one that reads cd's is faulty, but try uninstalling the dvd drive first then re installing it to see if it cures it, if not the drive will need replacing. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
SOURCE: DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
SOURCE: Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
