20 Most Recent
Thomson RCA Bookshelf System with 128 MB MP3 Player, RS2052 Shelf System Questions & Answers
My rca 5 disk vertically
Try this... unplug the unit and turn it upside down. Have a small screwdriver ready. No plug the unit in and try to turn the wheel in the large slot clockwize. When you see the spring clip try to grab the white plastic stop and move it clockwize. This should eventually open the door. It did for me.
RCA rs2052 cd door won't
first switch off the system for a while like 30 minutes, then put it on
back.
You can try and reset it if it has reset functions on it.
If that dd not work out, in other to prevent further damage to the
player, call a radio repairer to adjust the rubber inside where the cd
opener is. It is somehow stiff and it needs to be free a little bit for
it to work properly again.
Also check the voltage of the light you are using on the system that
light affect it to.
Take care.
Hi, All the lights on display are off. The system
some of possibilities are:
a) a burnt out LED (light emmiting diode) inside the display (could be tricky or difficult to change it) or a faulty LED power supply line
b) if the light source is an electroluminescent panel, possibly the panel itself or the power supply is faulty (electroluminescent panels use an elevated voltage power supply which is in the shape of a small box somewhere inside the housing, with two wires going to the panel - it is also possible that the power supply is not in the form of a box but is in fact an integral part of the circuitry).
c) a loose wire contact - check the connectors for any broken wires, oxidation on contacts or loose solder points for connectors on the circuit board
Anyway, these are just possibilities so the trouble may as well be somewhere else in the system.
regards
3rq8 (Triarcuate)
Cd door won't open
You might remove the case and remove the disks. Uplug first.
Be carefully not to force or bend parts. retry
CD Door will not open
There is a problem with the device itself...what I would recommend you to do is to return it from the store you purchase it...there isnt anything phisycally you can do about the problem you are having...it is the device itself that is defective.
RCA RS2052 Bookshelf System
Have you tried cleaning the sensor on your stereo, and also the transmitter on the front of your remote? Otherwise check the battery terminals in the remote for corrosion to make sure the batteries havent leaked.
