Color Laserjet 3600 had a 50.9 error. I installed a maint. Kit and then the printer gave a 13.20.00 JAM INSIDE FRONT DOOR. I have not been able to find anything. I ran diagnostics:Component test and when I try to run the Fuser Pressure Release Motor test, it immediately gives the 13.20.00 error. I can't get it to print anything. What am I looking at here? Note: After the maint. Kit install I ran a config page and the second page didnt complete. It made it up to about 2" in the Fuser. Any help would be greatly appreciated
SOURCE: hp cp2025 paper jam message, no paper jammed, even when restarted gives message
try lubricate the paper lefter from down the printer - you must lubricate the two sides
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
