20 Most Recent HEWLETT-PACKARD T790 InkJet Plotter Printer Questions & Answers
In Diagnoses mode EEPROM reset has to do for resetting,
Entering the Diagnostics Menu
1. Make sure the product is switched off with the Power key on the side of the Touch Screen Panel, and not with the power switch on the back of the product.
2. Press and release the Power key to switch on the product.
3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel have come on and then press and release one after another Cancel> Home> Help buttons.
4. The 6 buttons on the Touch Control Panel will then blink 4 times; then wait until the product completes the initialization sequence and shows the Diagnostics menu.
5. In the Diagnostics menu scroll to EEPROM reset..
But we strongly recommends that useres are not suppose to do this activities, printer may disturbed all the way...
HEWLETT-PACKARD... | Answered on Mar 18, 2019
You can configure the printer's Internet connection from the Embedded Web Server or from the front
panel.
NOTE: If an administrator password has been set, it will be required to change these settings. Thus,
the administrator can prevent the printer from being connected to the Internet, if desired.
? In the Embedded Web Server: select Setup > Internet connection.
? Using the front panel: press , then , then Connectivity > Internet connectivity.
The following settings are available:
? Enable Internet connection: The default value is Yes.
Change to No
HEWLETT-PACKARD... | Answered on Sep 10, 2015
This is one of frequent error in this series.
as you know two types of media paths 1. roll media 2. Sheet media. In sheeteet media loading area, you can observe 'u' shaped(extremly right side where sheet media sits) plastic mould which paper passes through in it. This palstic mould contains paper sensor to sence the sheetmedia. If this sensor is dusty, printer will treats that sheet path accupied by media. The best method to clean this sensor is to blow pressure air in this sheet path area.bicycle pump is best for this process.. try it...
HEWLETT-PACKARD... | Answered on Sep 24, 2014
If carriage sits at right side., might be service station jammed, its not releasing the carriage assm..its critical issue., dont force to pull out the carriage, it may damage print heads.. pl contact professionals..
HEWLETT-PACKARD... | Answered on Sep 23, 2014
English please
HEWLETT-PACKARD... | Answered on Jun 29, 2014
No communication between the product and the Touch Control Panel
Corrective action: Try the following:
1. Check the event log at the EWS support pages to see if there is another SE (for instance 07:10) and troubleshoot the problem more accurately
2. Turn off the product and turn on again, and check to see if the error remains.
3. Upgrade the firmware
4. Check the condition of the USB cable, check it is not damaged or incorrectly connected.Reconnect USB cable (from Engine PCA to the Interconnect PCA or from Interconnect
PCA to the Touch Control Panel
5. Replace the USB cable
6. Replace the Interconnect PCA, see Interconnect PCA on page 315.
7. Replace the Engine PCA see EE Box on page 281
8. If the error continues, replace the Touch Control Panel
HEWLETT-PACKARD... | Answered on May 03, 2014
Please uninstall and re-install the printer software.
HEWLETT-PACKARD... | Answered on Mar 04, 2014
Both print heads are clogged, try to clean it manually if not succeeded replace both of them.. U can find how to clean print heads in you tube..
https://www.youtube.com/watch?v=Ztl_SiUdPLw
HEWLETT-PACKARD... | Answered on Sep 17, 2013
Process 1..
1. Switch the power off from the back of the product, wait two minutes, then switch it back on again.
2. Check the power cord; try connecting it to another power socket.
3. Check that the product is properly connected in all other respects.
4. Switch the power off from the back of the product; remove the Formatter; reinsert the Formatter; switch the power on again.
Process 2..
1. Turn off the product with the Power Key on the left of the Touch Control Panel.
2. Press and release the Power Key to turn on the product.
3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel come on and then press
and release one after another the RIGHT -> HOME buttons.
4. Wait for the unit to complete the booting process. The logs are now enabled in the product even if
the product hangs and shows a system error.
Once U got the error, check the error related spare, replace it, any help post your query..
Formatter snap:
how to replace pelt plotter hp t790
HEWLETT-PACKARD... | Answered on Apr 10, 2013
Try a different outlet and different power cord.
HEWLETT-PACKARD... | Answered on Sep 26, 2017
No doubt the feed rollers are worn.
HEWLETT-PACKARD... | Answered on Sep 22, 2017
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
HEWLETT-PACKARD... | Answered on Aug 02, 2017
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HEWLETT-PACKARD... | Answered on Mar 01, 2015
HEWLETT-PACKARD T790 InkJet Plotter Printer Logo
21 questions posted
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
InkJet HEWLETT-PACKARD
  • InkJet HEWLETT-PACKARD
Most Popular Question
reset hp t790
  • Office Equipment & Supplies
