Canon PIXMA MX300 All-in-One Printer Logo
Posted on Apr 05, 2009
Faxing issue when faxing I am only able to send one at a time instead of multiple pages
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1295
Points
10
To my knowledge, you can only fax multiple pages from the printer itself. Place the fax page on the glass, press "fax" ,then press "black" or "color" after doing this to all the pages, press "ok" They have now been sent. I am assuming that you have your phoneline connected correctly to the printer. You should be able to hear it on another phone extension when your fax modem dials.
1 Related Answer
Anonymous
  • 3085 Answers
  • Posted on Jun 09, 2009
SOURCE: Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
8helpful
Trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled. Doesn't matter if we are faxing one page or multiple pages.
trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled.
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
2answers
Will not fax but will receive
Sounds like you are faxing multiple pages through the document feeder and it is trying to grab a few sheets instead of just one.
If you are doing multiple pages make sure they are aligned and separated.
Maybe fan the pages and then pat them on a level surface to make sure they are aligned.
3helpful
2answers
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Open the document feeder (number panel). Make sure that a switch actuator is not stuck down.
Paper
most likely the seperation pad has worn out and possibly the roller parts sould be still avalible for this model. besides replaces the worn parts in the machine there is no quick fix besides cleaning the rollers and the seperation pads in the machine with a damp soapy cloth with like dish soap and wiping dry with another cloth it might work better for alittle longer or till you get replacement parts.
old marine
old marine
ZJ Limited
ZJ Limited
