20 Most Recent HP LaserJet M1522nf Multifunction Printer (CC372A) Questions & Answers
Print is blurry. Tried a new cartridge, no help. Will print from 3 computers, but it is blurry. Any ideas?
If it is a LaserJet printer then the fuser needs replaced
5/21/2022 3:20:57 PM • HP LaserJet... • Answered on May 21, 2022
Printer says the ADF door is open, I opened and closed the computer no change what else should I try?
ADF is the top part where you place faxes and multiple sheets to copy. Check to make sure that it is sitting completely tight and closed. This is the part that sits above the glass. If it seems closed tight, try to open this top raised part of the printer and then close it again. Uplug the printer and plug it in again.
11/15/2021 7:54:54 PM • HP LaserJet... • Answered on Nov 15, 2021
3answers
What is the Hostname of hplaser jet M1522nf
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
5/17/2020 9:46:56 AM • HP LaserJet... • Answered on May 17, 2020
4answers
HP Laserjet M1522nf - scanner and fax won't
HP Laserjet M1522nf Update 7 drivers
9/1/2019 5:48:30 AM • HP LaserJet... • Answered on Sep 01, 2019
How to fix hp laserjet m1522nf with ready light is not on and firmware corrupt ready 2 download
try finding a utube video on the subject there shud be vids on someone else who has done the fixing as well , anything else you need you can find it here>>www.discountbargainprices.com
2/17/2019 12:22:07 PM • HP LaserJet... • Answered on Feb 17, 2019
3answers
10.1000 Supply Memory error. How can I fix that?
sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site. http://www.infinityimaging.com/cgi-local/SoftCart.exe/online-store/scstore/p-2300.html?E+scstore
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
1/24/2019 4:22:55 PM • HP LaserJet... • Answered on Jan 24, 2019
2answers
My hp laserjet M1522nf is
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
10/19/2018 8:39:26 AM • HP LaserJet... • Answered on Oct 19, 2018
Hp laserjet m1522 50.3 fuser error
REPLACE FUSER.
10/10/2018 7:54:41 PM • HP LaserJet... • Answered on Oct 10, 2018
2answers
Adf door is open...
Try a nvram. While the printer is off, hold down the down arrow and the cancel button and turn the printer back on, hold down until permanent storage init is displayed on the lcd.
Al
9/3/2018 4:30:33 AM • HP LaserJet... • Answered on Sep 03, 2018
Hi i have a printer
u go to settings of printer in which check the default print.
3/27/2018 8:48:31 PM • HP LaserJet... • Answered on Mar 27, 2018
How to reset password in hp laserjet m1522nf
You can try setting the printer back to fabric settings following this simple steps:
1) Turn the printer off
2) Now while the printer is off, press and Hold the down arrow and cancel button
3) Keep them depressed and turn the printer back on while holding those keys
4) you will see a message on the display that reads "permanent storage init" at this point you can release the buttons
After this steps you need to wait about 3-4 minutes and then the printer will come back to ready
Password reset DONE !!
If you need more assitance you can contact me at :
[email protected]
2/17/2018 5:55:56 AM • HP LaserJet... • Answered on Feb 17, 2018
How to service the HP LaserJet M1522nf
Give a call to HP Support to get the issue resolved (877-690-9305)
2/2/2018 3:21:55 PM • HP LaserJet... • Answered on Feb 02, 2018
2answers
Humming sound coming from printer
HP LASERJET M1522 NF MFP PRINTE Printer
where is the chip brain, I want to fry it !....It's so dump printer !
2/2/2018 3:20:01 PM • HP LaserJet... • Answered on Feb 02, 2018
My M1522 MFP printer is
When you changed from Network to USB cable, one or both of two things may have occurred. First check your printers list in the control panel. You may find you have two apparent installations of the device. If so try a test page from each install and record the port settings for the one that responds. Delete the other and re-test. If the machine fails to print on any setting, delete ALL installations for the device and re-install from fresh with the USB cable. You may also need to go into the settings on the device itself and disable any network settings.
10/16/2017 8:15:30 PM • HP LaserJet... • Answered on Oct 16, 2017
Hp laserjet m1522nf. when you
See my tips section for the solution to this. This error is covered by HP and they will repair at no charge for almost all M1522's ever made.
10/14/2017 5:33:43 AM • HP LaserJet... • Answered on Oct 14, 2017
tip
EPSON PRINTER SUPPORT
USA-printer-support is the best printer service provider company. We are providing exceptional support when problems occur in Epson printer problem. Epson printer support phone number proves out to be the most dependable source for fixing all technical with Epson printer device. Our tech support team will be gives best services to your when you will call to me related Epson printer related problem. Our services are available 24*7. EPSON PRINTER SUPPORT NUMBER +1-800-978-0818. To get more details visit our website. http://www.usa-printer-support.com/epson-printer-support
2answers
Can not fax or recieve
Fix for HP LaserJet error 49
7/1/2016 12:01:33 AM • HP LaserJet... • Answered on Jul 01, 2016
2answers
Need software download for M1522nf to new windows
software download for M1522nf to new windows 7
6/30/2016 11:55:01 PM • HP LaserJet... • Answered on Jun 30, 2016
HP Laserjet M1522nf display not working
if it is frozen on boot, you need to replace formatter or warm its chip until 280°C for 20-30 seconds.
9/16/2015 2:36:56 PM • HP LaserJet... • Answered on Sep 16, 2015
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
585 questions posted
Vinaya Kumar...
Vinaya Kumar...
Ekse
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
gives bang sound when powered cartridge
  • Office Equipment & Supplies
