When i try to use deep cleanig on my printer canon Pixma MP150 it give a feed back stated Service Error 5010..why????A.S.A.P
Em healer, posted on Jan 20, 2008Error 5010 Possible solution. I did this and it worked but I do not know if the solution is related to the printer's error code. 1. Unplug printer....wait 30 seconds then plug it in. Make sure the unlock symbol is on unlocked. you can find this when you lift up the heavy top cover to see the paten. 2. Reset. Turn off. Turn on. Reset 3. If this does not work. Look inside close to where the paper comes out (from the front.) There is a little door that can be flipped up or down. Flip this door up. Repeat steps 1 and 2.
Posted on Jan 20, 2008
Errore code 5010
Posted on Dec 25, 2007
new printer and having the same problem help
service error 5010
indeed this procedure solved problem - thanks
