My Canon Pixma iP 6600D printer has printed out several times today using just black in even though there is colour ink in it,I went to 'Print - Preferences' & in the little grayscale printing box there is a tick, each time I have gone to print something the tick is back there again even though I keep removing it. How can I get it to stop being there all the time
1st option, set the default profile in the printer properties. if it doesnt work. this will change all the settings that you might missed to check to go back to factory setings. also, check if your color cartridge is ok and with enough ink and not dis abled
2nd option, run any 3rd party software that can fix some windows system files or something like that. try to scan pc for viruses
3rd option, reformat your pc. maybe windows files that allows your printer to work are having problems or corrupted, base on the thing that you mentioned that it goes back to the grayscale settings
SOURCE: Canon Pixma ip1000 does not print Grayscale and other colours
I have lost the printer driver of Canon PIXMA iP1000, would you please assist me to dowload the driver free.
regards, Anup
SOURCE: my canon i850 won't print black. ink is full
The black printhead is blocked, you will need to replace it.
SOURCE: canon ip1000 not printing even after replacing a new ink catridge
This might seem a dumb answer, but have you removed the PULL tab over the breathing hole. I had a similar problem until I realised my error.
SOURCE: Hi. I have a Canon
Hi
Follow these steps;
- Open the document you want to print
- Go to 'file'
- 'Print'
- click 'properties' in the print window
- in the menu select 'Maintenance'
- in the 'Maintenance' click 'Ink Cartridge Settings'
- select 'Black Only'
- click 'OK'
- again click 'OK'
- now you can print only using the black ink in the printer.
Hope this helps, Please rate if this solution was helpful. thanks!
I did a search & found this [To reset the print color, go to the Print Preferences, make sure Grayscale is not checked. Check Print Advisor, click Default. You should be back to printing color.] hopefully it will solve my problem
Problem fixed by doing the above
No problem isn't fixed, I just went to print & the grayscle box is ticked again this is really annoying
