SOURCE: Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: Paper feed feeding multiple sheets
The most likely cause of this problem is a paper feeder malfunction. Because you were not specific in the model you have, repair could be rather variable.
One plausible cause is the paper rollers have tried up. Normally when the small rubber rollers grip the paper, the friction generated by a properly moisturized feeder can grip a single sheet. If your rollers are getting dry, you can use some rubbing alcohol on a q-tip and rub it on the rollers. Make sure not to use isopropyl alcohol, that will cause the rollers to dry out even more. I've heard of people using WD-40, but I've never tried that. You would want the WD-40 to dry a while otherwise it will leave greasy residue on your nice white paper.
Another cause could be a small object (paperclip, staple, raisins) stuck in the paper feeding mechanism. Carefully inspect the feeder, comparing one side to another, and gently pushing on the movable parts to make sure they can move free. You don't want to push too hard or you could knock out a needed spring or damage the plastic gears.
Hope this helps!
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Same exact thing.
