I have changed the black cartridge & replaced the toner container. The message on the machine is 'Check the toner container' It's installed correctly and the door is closed. I have turned the machine off & back on to reset but the error message remains???
SOURCE: the "check waste toner box"
Was inside of the bottle with soapy water
Look at the U shaped sensor that the bottle goes into...blow out.
Posted on Oct 14, 2008
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
SOURCE: Abnormal Toner Usage
I called Kyocera suppor today. They say this is a known problem with the sensor that a dealer has to fix.
Posted on Jun 02, 2009
SOURCE: display says 'replace cartridge' & 'clean
Try shaking gently the toner cartrige!!! This may help mix the toner which may be stuck together especially if the printer is not used often enough or stored in a place that is not as specified (humidity, ventilation, etc...).
Posted on Nov 26, 2009
SOURCE: Error message "check waste toner box". New
Check your waste toner box. At the side of the printer is a container for the extra toner to be stored. Everytime you change your cartridge you need to change the waste toner container. Carefully open side panel and remove waste toner bottle. There is a button you need to push do not force the bottle out.
Remove lid of new waste toner bottle and put into place and close side panel. Follow link for further details or use your setup guide that came with the printer on how to install the waste toner bottle.
http://usa.kyoceramita.com/americas/jsp/upload/resource/15865/0/2000D-3900D-4000DMLIIR1.1.pdf
Posted on Jun 08, 2010
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
