Question about Kyocera FSC2126MFP AllInOne Laser Printer
My machine shows f 248 error - Kyocera FSC2126MFP AllInOne Laser Printer
Posted by rcvt on
  • Mike Lyste Apr 27, 2016
    f errors are always bad print jobs find it and delete it
Doug Sneddon
    New Friend:
  • 60 Answers
F248 is communication problem ,it some times happens when the printer cannot understand the data coming from the computer from certain program's or a specific file .reset the printer clear any print jobs on the pc and try print a test page if you're still getting that error you will need to get a service engineer to upgrade to the latest firmwarec
Posted on Aug 01, 2012
  • Kyocera HP Expert
    Kyocera HP Expert Aug 09, 2014
    F248 is corrupted Data, unplug the network cable, delete your jobs from the que of your pc, Turn the machine on and it should work fine. There is new firmware for the machines to avoid this issue.
  • Kyocera HP Expert
    But if you get F 247 or 248 even if you unplug the network cable and after rebooting the machine, this means you have harddrive issue. formatting it might fix it temp but wat i experinced is you have to change the harddrive.
Dominik Svoboda
    New Friend:
Try to choose different driver in Control Panel/Devices and Printers/Kyocera ***/Printer/Properties/Advanced/Driver/New Driver
Posted on Sep 27, 2012
  • Frieda Olivia
    Frieda Olivia May 12, 2014
    Thank You...it resolve the problem :)
  • Projetos Yukaline
    Projetos Yukaline Apr 29, 2019
    it solve my problem toooo!!!!! thanksss!!
Kyocera HP Expert
  • 532 Answers
Everything mentioned up is true, the latest solutions from kyocera is :
update firmware
update print driver.
sometimes by clearing the jobs it does work but when you print from online it might throw this error.
if the error cannot be cleared by deleting the old jobs in the que, you need to replace the hard drive.
it depends what model you have but kyocera had some harddrive issue with the 3500i and 3500ci series.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on May 01, 2016
justin
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Firmware is a must and also latest driver 6.2 , release notes include that code/ ........
Posted on Nov 30, 2014
Joseph Koata
    New Friend:
  • 12 Answers
Its a communication problem between your PC or laptop, check your usb cable cos sometimes usb cables faulty, checked if your usb port on your PC or laptop disabled, finally just replaced the usb board from your printer, seek your nearest service representative.
Posted on Jun 10, 2013
Tip
Remove Recycle Bin From Desktop
<p><span><span>&oslash;<span> </span></span></span><span>Click Start Menu</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Click on Run</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Type "Regedit" and click OK</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Navigate to the following key </span><br /> <p><span><span>&oslash;<span> </span></span></span><span>HKEY_LOCAL_MACHINE</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>SOFTWARE</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Microsoft</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Windows</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>CurrentVersion</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>explorer</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Desktop</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>NameSpace</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Click on the "Recycle Bin" string in the right hand pane. Hit Del, click OK.</span><br />
on Dec 27, 2010 | Computers & Internet
How do I fix error cf 248 for my Kyocera 1128. I have tried several times shutting off. Taking out toner and checking paper jam
If its what I think it is, then the error occurs when your machine is receiving a corrupted print job. This is shown by the data light flashing for several minutes before showing the error.
If this is the case, then unplug the network cable from the machine, power the machine off & on & wait until it comes ready. If the machine comes ready then try a photocopy. If that works then it is a corrupt print job. Before plugging the network cable back in, check any PC's that print to the copier & check the print queues to see if any PC's are still spooling a print job. If so, delete the print job & re-connect the network cable & test the machine.
I have found most corrupt print jobs will be from the internet & will have "www......" listed as the print directory list.
Hope this helps.
Dave.
Feb 13, 2016 | Kyocera Office Equipment & Supplies
Turn on tv get error message Lamp needs to be replaced and the Lamp Hour meter needs to be reset. I still have picture how do I reset this error message
Howdy,
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Mar 25, 2009 | Panasonic PT-44LCX65 Television
How do I bypass the wrong cartridges, install original print cartridges that were shipped with you printer error?
Again I must ask,What is the Make and Model Number of the Printer your working on. ? I wish you people would provide more information so we can assist you better.
Mar 07, 2009 | HP Office Equipment & Supplies
Help set up a singer 248 sewing machine
You can order a manual for this from Singer: http://www.singerco.com/accessories/
Mar 28, 2008 | Dishwashers
Kyocera FSC2126MFP AllInOne Laser Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
George Mclaughlin
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
