Question about Kyocera FS-2000D Laser Printer
Check your waste toner box. At the side of the printer is a container for the extra toner to be stored. Everytime you change your cartridge you need to change the waste toner container. Carefully open side panel and remove waste toner bottle. There is a button you need to push do not force the bottle out.
Remove lid of new waste toner bottle and put into place and close side panel. Follow link for further details or use your setup guide that came with the printer on how to install the waste toner bottle.
http://usa.kyoceramita.com/americas/jsp/upload/resource/15865/0/2000D-3900D-4000DMLIIR1.1.pdf
Posted on Jun 08, 2010
There is one more think that I can stongly advise you.
You should clean the spot with an wet handkerchief. Try to push the button where you put the top of your waste tonerbox, and wipe it. It was useful for me, and sloved the same problem.
By the way tehere is one more think. There is an gray button. Try to make it totally vertical!
Posted on Sep 25, 2011
SOURCE: I keep cleaning the toner/printer
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Posted on Nov 22, 2010
SOURCE: I get error message "waste
Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
Posted on May 10, 2011
SOURCE: Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Posted on Feb 05, 2009
SOURCE: Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Posted on Dec 07, 2008
SOURCE: I install the toner waste bin, but I still get an
There is photo-optic detector, clean two side emitor and receiver.
Posted on Jan 04, 2011
Mar 07, 2016 | Konica Minolta Bizhub C452 Color Copier,...
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
Feb 15, 2011 | Lexmark C534dn Laser Printer
Jan 04, 2011 | Samsung CLP-315W Laser Color Printer
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Feb 27, 2009 | Gestetner Copier
23,537 people viewed this question
