20 Most Recent
Canon imageRUNNER ADVANCE C5051 Questions & Answers
E000075 0003
E075 is the transfer belt displacement error. Remove the ITB and check if the belt isn`t a little bit to low (marks on the frame) If it is, just correct it, if it happen again, change the frame of the itb.
11/15/2019 4:35:29 PM •
Canon...
Answered
on Nov 15, 2019
How do I disable double sided printing
- Open a document.
- Click File ' Print.
- Select the correct copier.
- Click the drop down arrow (below the Pages field).
- Select Finishing.
- Change the Print Style to 1-sided.
- Click the Presets field.
- Select Save As.
- Rename the Preset field.
- Click OK.
- Select Print or Cancel.
3/5/2015 2:36:09 AM •
Canon...
Answered
on Mar 05, 2015
What's E00025-2c0
Error in Cover Sensor (PS14) in M Toner Container
Description Unable to detect opening of the Toner Container Inner
Cover when removing the Toner Container.
Remedy Identify the cause of the error whether it is due to link
mechanism to open the Toner Container Inner Cover or
problem at the Toner Container Inner Cover Sensor side. ?
1. Perform the user mode (Adjustment/Maintenance>
Replace Specified Toner) to check if the Toner Container
Inner Cover opens normally (damage, slide of shaft area,
etc.). ?
2. Check if the Toner Container Inner Cover Sensor is
soiled and the installation of the sensor. ?
3. Check the service mode (COPIER> I/O> DCON> P024
bit9) to see that the output value of the Toner Container
Inner Cover Sensor is changed normally when opening/
closing the Toner Container Inner Cover. ?
If it is normal, the value becomes 0 by rotating the Set-on
Drive Shaft with the attached tool and opening the Toner
Container Inner Cover. When closing the Toner Container
Inner Cover by hand, it becomes 1. ?
3-1. When the Toner Container Inner Cover is not opened
although the Set-on Drive Shaft rotates, check the drive
system from upstream (Set-on Drive Unit -> Hopper Unit
-> Bottle Base Unit -> Toner Container Inner Cover Unit). ?
If it is damaged, replace the damaged part and then
perform step 5 and later steps. ?
3-2. When the output value is not changed normally
although the Toner Container Inner Cover can be opened/
closed, check the Sensor Harness (to see if the harness
is caught, disconnected or physically removed, *including
the Relay Connector). ?
If there is no problem, replace the sensor. After checking
the output value in step 3, perform step 5 and later steps. ?
4. If the problem is not solved by replacing the foregoing
parts, replace the Drum Driver PCB (UN4) and then
5. Clear the error in service mode (COPIER>
FUNCTION> CLEAR> ERR), and then turn OFF and then
ON the main power. ?
6. Replace the toner (reinstall the removed Toner
Container) at least once in user mode (Adjustment/
Maintenance> Replace Specified Toner), and check that
toner replacement can be performed normally.
2/13/2015 9:05:01 AM •
Canon...
Answered
on Feb 13, 2015
Tengo una Copiadora Canon IR 1023, a cada rato se atasca el papel, se queda al pasar por el rodillo del termico no sale, se arruga y atasca.
Si tu copiadora Canon IR 1023 se atasca constantemente con papel y se arruga al pasar por el rodillo t?rmico, aqu? hay algunas soluciones y pasos que puedes intentar:
1. Verifica el tipo y la calidad del papel: Aseg?rate de utilizar papel de calidad y del tipo adecuado para tu copiadora Canon IR 1023. Utilizar papel de baja calidad, h?medo, arrugado o demasiado grueso puede causar atascos.
2. Limpia el rodillo t?rmico: Si el rodillo t?rmico est? sucio o presenta residuos de tinta o polvo, puede provocar atascos de papel. Apaga la copiadora, desench?fala y deja que el rodillo t?rmico se enfr?e por completo. Luego, utiliza un pa?o suave y limpio ligeramente humedecido con agua para limpiar cuidadosamente el rodillo t?rmico. Evita usar productos qu?micos agresivos o solventes, ya que pueden da?ar el rodillo.
3. Revisa las gu?as de papel: Aseg?rate de que las gu?as de papel est?n correctamente ajustadas seg?n el tama?o y la orientaci?n del papel. Las gu?as mal ajustadas pueden causar atascos y arrugas en el papel. Ajusta las gu?as cuidadosamente para que est?n en contacto suave pero firme con el papel.
4. Verifica y limpia los sensores de papel: Los sensores de papel son peque?os dispositivos que detectan la presencia y el movimiento del papel dentro de la copiadora. Si estos sensores est?n sucios o defectuosos, pueden causar atascos y otros problemas. Consulta el manual del usuario de tu copiadora para localizar los sensores de papel y c?mo limpiarlos adecuadamente.
5. Realiza un mantenimiento regular: Programa un mantenimiento regular con un t?cnico autorizado de Canon para verificar y limpiar los componentes internos de la copiadora. Un mantenimiento adecuado puede ayudar a prevenir atascos y otros problemas.
Si los problemas de atascos de papel persisten a pesar de seguir estos pasos, ser?a recomendable contactar a un t?cnico especializado de Canon o al servicio de atenci?n al cliente de Canon para obtener asistencia adicional. Ellos podr?n proporcionarte soluciones espec?ficas para tu modelo de copiadora Canon IR 1023 y brindarte un soporte m?s detallado.
What should i do to fix this error? Canon i-sensys mf 9220 showing system error E000003 on screen
What is the Canon i-sensys mf 9220 system error E000003?
The Canon i-sensys mf 9220 system error E000003 is an error that can occur when you're trying to print documents. Basically, it means that the printer can't communicate with the computer. This can be caused by a number of things, but the most common cause is a problem with the USB cable.
How to fix the Canon i-sensys mf 9220 system error E000003?
If you're getting this error, the first thing you should do is check the USB cable. Make sure that it's properly connected to both the printer and the computer. If the cable is loose or damaged, try replacing it with a new one.
I hope this helps!
Can I use my chromebook to print from a Canon MG2522
Chromebooks do not use drivers to install printers. They use Google Cloud print. There are two methods of printing with Google Cloud print, using a Google Cloud Print ready printer or setting up the service on your computer.
