SOURCE: HAve an LG dryer that blows cold air
The dryer outlet hose leads somewhere outdoors. Go outside and make sure that there is nothing (lint, leaves, etc) blocking the outside end of the outlet. This would be the first and simplest solution before you consider anything else.
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
SOURCE: LG dryer DLE2516W keeps flashing check lint screen
That's just a reminder to clean the filter before every use.
