20 Most Recent LG DLE2516 Electric Dryer Questions & Answers
0answers
When I first use dryer it runs great. When I pit the second load in it runs for 3 seconds and shuts off. About 15min. It runs good again. What could be problem
overheating thermostat switch could be the cause try different temperature like cooler or hotter if the same thing happens then get a tech person to fix it because if you don't know anything about leave it alone because it could cause a fire .ie burn the clothes in the dryer
5/17/2015 5:04:15 PM • LG DLE2516... • Answered on May 17, 2015
LG Dryer displays CL on screen. What to do?
Makes no mention in the manual about a CL error If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/27/2014 7:06:14 PM • LG DLE2516... • Answered on Sep 27, 2014
How would I know if the main control board on my LG DLE2516 is defective?
There is no way to test other than replacement.
9/1/2014 3:07:32 PM • LG DLE2516... • Answered on Sep 01, 2014
Check filter light is on
check both back and front system for blockage.. venting sytem may have obstrution
12/19/2013 8:08:37 AM • LG DLE2516... • Answered on Dec 19, 2013
Felt Gasket on lint filter is coming apart
replace filter
12/19/2013 8:07:35 AM • LG DLE2516... • Answered on Dec 19, 2013
Check dryer vent light comes on
check the back venting system and the front system still can be clogged by particals getting past the screen look inside the fornt system with screen out.
12/19/2013 8:07:06 AM • LG DLE2516... • Answered on Dec 19, 2013
LG Dryer dinging sound
Turn the drum by hand to see if it makes the noise.
7/18/2013 1:27:13 AM • LG DLE2516... • Answered on Jul 18, 2013
Filter light
Could you please describe the problem you are having a little better?
11/9/2012 8:31:19 PM • LG DLE2516... • Answered on Nov 09, 2012
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
3/11/2012 9:46:57 PM • LG DLE2516... • Answered on Mar 11, 2012
Dryer runs normal but with
pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port.
11/14/2011 4:18:32 PM • LG DLE2516... • Answered on Nov 14, 2011
My LG electric dryer is not blowing any heat
Have you checked your circuit breakers to make sure they have tripped??Look at the junction box behind the dryer where the power cord connects to the electrical system of the dryer. Open the panel and make sure that the connection is clean and tight. If it has any burn marks, you will need to replace the whole wire harness under LG's repair policy.If these problems are eliminated, then you may have a problem inside the heating element or it's high limit switch which is inside the dryer and require disassembly.Hope this helps.
11/6/2011 1:17:40 PM • LG DLE2516... • Answered on Nov 06, 2011
LG DLE2516 Electric Dryer Logo
89 questions posted
Top LG Dryers Experts
Marvin
Marvin
Steve
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
check dryer vent light comes
  • Dryers
