20 Most Recent LG WM-3677HW Front Load Washer / Dryer Questions & Answers
3answers
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
3/20/2020 4:01:22 PM • LG WM-3677HW... • Answered on Mar 20, 2020
0answers
0answers
Lg front end washer smoking on spin cycle
check belt and motor windings
5/25/2015 10:25:33 PM • LG WM-3677HW... • Answered on May 25, 2015
WM3987HW Filter
www.lg.com/us/support
6/10/2014 10:47:03 AM • LG WM-3677HW... • Answered on Jun 10, 2014
Start button take long to activate and doors leak
When you press start button the signal is sent to the main board. The leak is from a bad bellow that rubber on you door, if your door is not damage. it's not sealing with the door.
5/3/2014 12:17:10 AM • LG WM-3677HW... • Answered on May 03, 2014
My washing machine does not spin and drain
becouse the water in drum machine not spining,,chek the drain motor,properly,,
2/22/2014 7:04:15 PM • LG WM-3677HW... • Answered on Feb 22, 2014
0answers
Manual link
Be the first to answer 7/31/2013 7:41:25 PM • LG WM-3677HW... • Posted on Jul 31, 2013Be the first to answer
2answers
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
6/19/2013 3:54:46 AM • LG WM-3677HW... • Answered on Jun 19, 2013
LG WM3677HW Won't turn ON.
Ok try this .
You say you know your way around electric. Here is the service manual incl drawings.
LINK
1/6/2013 2:15:46 AM • LG WM-3677HW... • Answered on Jan 06, 2013
LG front load washer doesnt turn on after one full cycle
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
1/2/2013 10:29:51 AM • LG WM-3677HW... • Answered on Jan 02, 2013
LG drier will not dry
Check the heating element for continuity. Here is the part if you find it bad.
11/4/2012 5:44:37 PM • LG WM-3677HW... • Answered on Nov 04, 2012
LG WM-3677HW Front Load Washer / Dryer Logo
58 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
remove top lg wm2277h washing machine
  • Washing Machines
