How to remove plastic cover that covers the light bulbs
I think the best way to explain how to change the light bulb can be found on page 26 of the=> JFC2089HE User Manual If you have problems with the above link then click HERE and then enter your model number and answer the questions above the plaace you enter model number. I will be here to answer any questions you may have Thanks Sea Breeze
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download.
I can't get the cover off without forcing it.. I don't want to break it so I gave up...for now.
Hang in there and I believe you will be able to get in there to change the light bulb. I'm here if you have questions, Thank You, John Tripp
Thank you
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
